Hi, I created these stringers with Sweep. I capped the lower two stringers with a strange mesh result.
Any ideas?
Strange mesh.3dm (340.0 KB)
Any ideas?
Looks like you have accidentally set your crease splitting to no (sometimes Rhino does this by itself, it’s a bug).
To fix the existing objects: Select your objects, run the command DivideAlongCreases (SplitAtKinks=Yes).
To prevent this from happening in the future: Run the command CreaseSplitting and set SplitAlongCreases=Yes.
HTH, --Mitch
Thanks Mitch! That was fast!
Hi Thomas- are you using any non-default plug-ins, like T-Splines, or Orca etc? (trying to find someone to blame for resetting this CreaseSplitting state…)
thanks,
