I’m also a bit baffled by this one …
Might there be a solution to the below issue? I’ve been having the exact same issue on my office machine. For reference, it’s running SR11 (which as of 06.01.15, is up to date).
I'm baffled by this one.
Lately, whenever I run Rhino 5, I'm encountering a strange intermittent problem with the enter and escape keys. At first, they will…
Thanks for any insight (pun intended) -
-n
pascal
(Pascal Golay)
June 1, 2015, 6:42pm
2
Hi Nick - do you have any plug-ins, say Grasshopper, running?
Indeed - Grasshopper. Sounds like there is a known issue (if so, I need to do a better job searching)
-n
pascal
(Pascal Golay)
June 1, 2015, 6:46pm
4
Hi Nick- as far as I recall it is known of , but not really known enough to fix…
Ah ok, thanks for the note. Perhaps a future service release will address it …
wim
(Wim Dekeyser)
June 1, 2015, 7:50pm
6
Won’t happen unless a developer can reliably reproduce the issue. Can you try to run Rhino without Grasshopper and see if that changes things?
Sure thing, I’ll take note to see if the issue occurs after some extended usage without GH running and report back.
-n
