Hi all,
I’ll try to explain a strange issue I ran into yesterday. Unfortunately, I can’t share the model, but I have clear steps to reproduce the problem.
BETA (9.0.26251.12303, 8/9/2026)
Rhino_System_260910.txt (3.1 KB)
I’ve been working on a SubD part with symmetry enabled. The moment I activated Soft Transform, there was a noticeable delay before the falloff preview (the blue painted area) appeared.
I started moving some points using the Gumball (likely with Align to Control Polygon). After a second, the model disappeared, and it became impossible to see any other geometry in the viewport.
I tried several troubleshooting methods, but apparently something happened to the geometry that caused the viewport camera and target locations to break completely.
I tried importing the model into a clean file, and the problem persisted—confirming that the issue is tied to the geometry itself.
BoxEdit reports the dimensions of the problematic part as
0, 0, 0. -
If I delete the layer containing the broken part and run
_4View, the display issue disappears.
I managed to create a bounding box of the broken SubD part, and this was the result:
World coordinates:
min =
328.436, -1.69448e+98, 644.917 -
max =
2.89993e+99, 1.69448e+98, 3.36375e+99 -
dimensions =
2.89993e+99, 3.38896e+98, 3.36375e+99 millimeters
I’ve attached the bounding box file here for you to examine:
Laborda_BOX.3dm (144.9 KB)
Any insight or help would be greatly appreciated!
