Hi all, I use macros to change views within a particular viewport and have noticed some strange cplane behavior that I would like to report. If I start with a Perspective viewport and change the view to Left (by running an alias linked to ! _setview _world _left) and then change the view to Perspective again (by running ! _setview _world _perspective _Cplane _World _Top) the Cplane is now vertical instead of horizontal which I can only presume is not intentional. I am wondering if this is a bug? Sometimes you have to switch between Left view and Perspective
a couple of times before the cplane goes vertical.
Hi Pascal, I do have Cplane world top as part of my macro.
The macro for setting the viewport to left view is ! _setview _world _left
and then the macro for setting the viewport to perspective is ! _setview _world _perspective _Cplane _World _Top
Letâs say I run 4_view twice so all the viewports are in their default position and I double click on the Perspective viewport to make it primary. Followed by the macro for left view, followed by the macro for perspective, followed by the macro for left view and then followed by the macro for perspective one more time, the cplane is now vertical. The only way I can get the cplane to correct itself is to set Cplane to World Top. Is this as it should be?
Command: _Open
Name of the file to open ( UpdatePromptUpdateBlocks=Yes Browse ): âC:\Users\Cosmas Demetriou\Dropbox\LITL (1)\12_Shared_Assets\Matter_Port_Scans\Polish Social Club\Matterport_BanquetHall.3dmâ
Loading Legacy Rhino Render, version 1.50, Feb 8 2022, 14:35:44
Successfully read file âC:\Users\Cosmas Demetriou\Dropbox\LITL (1)\12_Shared_Assets\Matter_Port_Scans\Polish Social Club\Matterport_BanquetHall.3dmâ
Command: pp
Command: _setview
Choose coordinate system ( CPlane World ): _world
Choose world view ( Top Bottom Left Right Front Back Perspective TwoPointPerspective ): _perspective
Command: _Cplane
CPlane origin <0.000,0.000,0.000> ( All=No Curve Elevation Gumball Object Rotate Surface Through View World 3Point Undo Redo ): _World
Choose world CPlane ( Back Bottom Front Left Right Top ): _Top
Command: W
Command: _wireframeviewport
Command: lv
Command: _setview
Choose world view ( Top Bottom Left Right Front Back Perspective TwoPointPerspective ): _left
Command: pp
Command: _setview
Command: _Cplane
Command: f2
Command: _offset
Select curve to offset ( Distance=0.5 Loose=No Corner=Sharp ThroughPoint Trim=Yes Tolerance=0.001 BothSides InCPlane=No Cap=Flat OutputLayer=Current ): _Cap=Flat
Command: f2
Command: _offset
Command: _Options
Command: CommandHistory
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2021
Driver Version: 30.0.14.7284
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Users\Cosmas Demetriou\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp âIntelDenoiser.Windowsâ 0.6.4.0
C:\Users\Cosmas Demetriou\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp âNVIDIADenoiser.Windowsâ 0.4.3.0
So it looks like the CPlane > Top is there but not being executed⌠I cannot rgink what might be going wrong - if you open a new file and make a box - and run these command macros, does it work? Incidentallty you might take the â!â out from these macros - the commands are all nestable.
Good morning @Pascal following your instructions, when I open a new file and make a box and run these commands the same thing happens. The cplane ends up vertical. See the very short video attached.
