10/20/2025 7:24:55 PM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Operation timed out.
---> System.Net.Sockets.SocketException (60): Operation timed out
at System.Net.Sockets.NetworkStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
at System.Net.Security.SslStream.EnsureFullTlsFrameAsync[TIOAdapter](CancellationToken cancellationToken, Int32 estimatedSize)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.Sockets.SocketAsyncEventArgs.TransferCompletionCallbackCore(Int32 bytesTransferred, Memory`1 socketAddress, SocketFlags receivedFlags, SocketError socketError)
at System.Net.Sockets.SocketAsyncEngine.System.Threading.IThreadPoolWorkItem.Execute()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
at System.Threading.Thread.StartCallback()
--- End of stack trace from previous location ---
--- End of inner exception stack trace ---
at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder`1.StateMachineBox`1.System.Threading.Tasks.Sources.IValueTaskSource<TResult>.GetResult(Int16 token)
at System.Net.Security.SslStream.ReadAsyncInternal[TIOAdapter](Memory`1 buffer, CancellationToken cancellationToken)
at System.Threading.Tasks.ValueTask`1.ValueTaskSourceAsTask.<>c.<.cctor>b__4_0(Object state)
at WebSocketSharp.Ext.<>c__DisplayClass9.<ReadBytesAsync>b__8(IAsyncResult ar)
10/20/2025 7:52:29 PM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
at System.Net.Dns.GetHostEntryOrAddressesCore(String hostName, Boolean justAddresses, AddressFamily addressFamily, Nullable`1 startingTimestamp)
at System.Net.Dns.GetHostAddresses(String hostNameOrAddress, AddressFamily family)
at System.Net.Sockets.Socket.Connect(String host, Int32 port)
at System.Net.Sockets.TcpClient.Connect(String hostname, Int32 port)
at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
at WebSocketSharp.WebSocket.setClientStream()
at WebSocketSharp.WebSocket.doHandshake()
at WebSocketSharp.WebSocket.connect()
1 closed polysurface added to selection.
Command: _Delete
Deleted 1 object.
10/20/2025 8:29:03 PM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Operation timed out.
10/20/2025 9:03:28 PM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer.
---> System.Net.Sockets.SocketException (54): Connection reset by peer
10/21/2025 1:02:22 AM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer.
10/21/2025 3:37:54 AM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Operation timed out.
10/21/2025 9:56:04 AM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
Command: _New
Command: _New
10/21/2025 11:16:44 AM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Operation timed out.
10/21/2025 11:18:11 AM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
10/21/2025 11:20:11 AM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
10/21/2025 11:22:11 AM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
10/21/2025 11:24:11 AM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
10/21/2025 11:26:11 AM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
10/21/2025 12:46:49 PM|Fatal|<>c__DisplayClass17.<startReceiving>b__16|System.IO.IOException: Unable to read data from the transport connection: Operation timed out.
10/21/2025 12:48:31 PM|Fatal|WebSocket.connect|System.Net.Sockets.SocketException (00000005, 0xFFFDFFFF): nodename nor servname provided, or not known
Command: _CommandHistory
Started rhino maybe 20h before…
I get strange above message in the commandline.
what s going on there ?
systeminfo_tomp_25-10-21.txt (7.0 KB)
