When in layout (and using sections) there appears to be a bug where the items just keep ‘disappearing’ if I double click in one of the layout views the item appears again…
Very odd.
Hi Bill,
Please run SystemInfo in the Rhino command line and post the result.
Thanks!
Thank you for the reply,
System Info as follows…
Note that the problem is a new one and so may be graphics card update or Rhino update.
I have updated to most recent NVIDIA and INTEL drivers (that’s dedicated and in-built graphics cards)
Rhino 8 SR11 2024-8-20 (Rhino 8, 8.11.24233.01001, Git hash:master @ 6957666ece3a5f3ed7694c0ca66cdfea0407df3a)
License type: Commercial, build 2024-08-20
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.7
Computer platform: LAPTOP - Plugged in [76% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 7-24-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24233.1001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.11.24233.1001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24233.1001
Nothing unusual there, is this file specific? If possible please post a small example, you can upload privately here if need be.
Thanks Japhy,
Just sent an example file.
Thanks, not seeing the issue, but do get a missing image warning, so perhaps has something to do with it.
Try putting the images in the same folder, or removing for testing purposes (
ah OK…
yes will experiment with that… although the ‘views’ that I was having issues with didn’t have any jpgs… will report back if I see the same behaviour after following your instructions. Thanks for looking at it
definitely not related to jpgs. can reproduce on all drawings now,.,.
has started to affect work (elements 'mysteriously disappearing from one layout view to the next )
This one has been difficult to repeat but we are seeing it as well. What is your current systemInfo? Thanks
This should be fixed in the 8.11 release candidate that we shipped yesterday
Great news thank you !! downloading now
