Strange behavior ViewToCaptureFile
I have a small problems with the Output of my Rhino 6 mac outputs from ViewToCaptureFile (I used it for my Illustration work instead of Penguin or sth. similar)
I created a mode for Illustrations like Sketchup Style. In Normal Cases export them with my background but now if I deactivated my bgr (set it to transparent) Every line is also transparent and some color and material settings getting crazy.
Here is another sample where I colored some of the spikes green to show this phenomena.
Here is also the Display mode (by the way it is also for everyone to enjoy :))like Sketchup copy.ini (6.3 KB)
any ideas so far?
None.
The only thing I have tried when really strange things happen, is to reset the PLIST.
This will wipe your customization so make sure you have them saved.
https://wiki.mcneel.com/rhino/mac/resetprefs
If the problem persists after the PLIST reset, will you please supply a small sample file and all the instructions to repeat the problem here?
Thanks
A post was split to a new topic: Strange shadoes
