There is a modified implementation of Felkel & Obdrzalek’s algorithm ported from Java to C# here: https://github.com/reinterpretcat/csharp-libs/tree/master/straight_skeleton. One thing to note is that a robust implementation of Straight Skeleton calculation is quite a complicated algorithm and has a lot of edge cases (as Tom Kelley (“twak”) demonstrates)
I’ve used the C# code in Rhino/GH by rebuilding Rhino Polylines into the library’s own geometry primitives – see code below. Because this algo isn’t as robust as CGAL/twak, moving it to the origin and scaling it up can sometimes give better results (trying to avoid accumulating roundoff errors…). Also – if the shape you are skeletonizing is very orthogonal (ie lots of only right-angled), there is a chance this algo will fail because it cannot handle so many degenerate cases (even though it does introduce multiple split/edge event handling…)
(see http://www.twak.co.uk/2009/05/engineering-weighted-straight-skeleton.html)
Code:
public Polyline[] MakeStraightSkeleton(Brep brep)
// This must be performed near the origin and scaled up...
// Move to origin:
var duplicate = brep.DuplicateBrep();
var vertices = brep.DuplicateVertices();
var vector = new Vector3d(new BoundingBox(vertices).Center);
var translateFromOrigin = Transform.Translation(vector).Clone();
vector.Reverse();
var translateToOrigin = Transform.Translation(vector).Clone();
duplicate.Transform(translateToOrigin);
var scaleFactor = 1e4;
var scaleUp = Transform.Scale(Plane.WorldXY.Origin, scaleFactor);
var scaleDown = Transform.Scale(Plane.WorldXY.Origin, 1 / scaleFactor);
duplicate.Transform(scaleUp);
//Perform StraighSkeleton:
var innerLoops = new List<Polyline>();
Polyline boundary = null;
foreach (BrepLoop loop in duplicate.Loops)
Polyline loopPolyline;
var loopCurve = loop.To3dCurve().TryGetPolyline(out loopPolyline);
if (loop.LoopType == BrepLoopType.Outer)
boundary = loopPolyline;
else
innerLoops.Add(loopPolyline);
var sskOuterLoop = new List<SskVector2d>();
foreach (Point3d pt in boundary)
var sskVect = new SskVector2d(pt.X, pt.Y);
sskOuterLoop.Add(sskVect);
sskOuterLoop.RemoveAt(sskOuterLoop.Count - 1);
var sskInnerLoops = new List<List<SskVector2d>>();
foreach (Polyline innerLoop in innerLoops)
var sskInnerLoop = new List<SskVector2d>();
foreach (Point3d pt in innerLoop)
sskInnerLoop.Add(sskVect);
sskInnerLoop.RemoveAt(sskInnerLoop.Count - 1);
sskInnerLoops.Add(sskInnerLoop);
var sk = SkeletonBuilder.Build(sskOuterLoop, sskInnerLoops);
var lineList = new List<Line>();
var dupPtList = new List<Point3d>();
var faces = new List<Polyline>();
foreach (EdgeResult edge in sk.Edges)
List<SskVector2d> points = edge.Polygon;
var facePtList = new List<Point3d>();
foreach (SskVector2d sskVector2d in points)
var rhinoPt = new Point3d(sskVector2d.X, sskVector2d.Y, 0);
// Check if rhinoPt == input Polygon pt:
int dupCount = 0;
for (int i = 0; i < boundary.Count; i++)
if (rhinoPt.X == boundary[i].X && rhinoPt.Y == boundary[i].Y && rhinoPt.Z == boundary[i].Z)
dupCount = dupCount + 1;
if (dupCount > 1)
dupPtList.Add(rhinoPt);
facePtList.Add(rhinoPt);
var startPt = facePtList[0];
facePtList.Add(startPt);
Polyline face = new Polyline(facePtList);
// Move back:
face.Transform(scaleDown);
face.Transform(translateFromOrigin);
faces.Add(face.Duplicate());
return faces.ToArray();
