Hello
I am trying to read plugin data like this:
private ArchivableDictionary _docGlobalDatabase;
private ArchivableDictionary _docLocalDatabase;
public ShipWizardPlugIn() { _docGlobalDatabase = new ArchivableDictionary(1, "GlobalDatabase"); _docLocalDatabase = new ArchivableDictionary(1, LocalDatabase"); Instance = this; }
///<summary>Gets the only instance of the SPlugIn plug-in.</summary> public static SPlugIn Instance { get; private set; }
// You can override methods here to change the plug-in behavior on // loading and shut down, add options pages to the Rhino _Option command // and mantain plug-in wide options in a document. protected override Rhino.PlugIns.LoadReturnCode OnLoad(ref string errorMessage) { //Register DefaultPanel System.Type panelType = typeof(DefaultPanel); Rhino.UI.Panels.RegisterPanel(this, panelType, "S", System.Drawing.SystemIcons.Question);
//Document user data preparation Rhino.RhinoDoc.NewDocument += new EventHandler<DocumentEventArgs>(RhinoDoc_NewDocument); Rhino.RhinoDoc.BeginOpenDocument += new EventHandler<DocumentOpenEventArgs>(RhinoDoc_BeginOpenDocument);
return Rhino.PlugIns.LoadReturnCode.Success; }
private void RhinoDoc_BeginOpenDocument(object sender, DocumentOpenEventArgs e) { // A new document is being created, so clear out our string table _docGlobalDatabase.Clear(); _docLocalDatabase.Clear(); }
private void RhinoDoc_NewDocument(object sender, DocumentEventArgs e) { // A new document is being opened, so clear out our string table _docGlobalDatabase.Clear(); _docLocalDatabase.Clear(); }
/// <summary> /// The tabbed dockbar user control /// </summary> public DefaultPanel UserControl { get; set; }
#region Document user data overrides
protected override bool ShouldCallWriteDocument(FileWriteOptions options) { // Only write document data if there is something to write bool rc = (_docGlobalDatabase != null || _docLocalDatabase != null) ? true : false;
return rc; }
protected override void WriteDocument(RhinoDoc doc, BinaryArchiveWriter archive, FileWriteOptions options) { // Write plug-in document dictionary archive.WriteDictionary(_docGlobalDatabase); archive.WriteDictionary(_docLocalDatabase); }
protected override void ReadDocument(RhinoDoc doc, BinaryArchiveReader archive, FileReadOptions options) { // Read plug-in document data. //Read only if not opening new file, otherwise clear dictionary bool bKeepData = (options.NewMode || options.OpenMode) ? true : false;
if (bKeepData == true) { _docGlobalDatabase.Clear(); _docLocalDatabase.Clear(); } _docGlobalDatabase = archive.ReadDictionary(); _docLocalDatabase = archive.ReadDictionary(); }
It works provided that I have only GlobaDatabase. If I add LocalDatabase it crashes when opening new file.
It gives exception:
An exception of type ‘Rhino.FileIO.BinaryArchiveException’ occurred in RhinoCommon.dll but was not handled in user code
Additional information: ReadDictionary failed
I just realized that I try to read the same dictionary twice. Is it even possible to store 2 different dictionaries or should I make a third one containing 2 others just for writing to file and then split it when reading?
