Storing run-time data in a plugin
Hi!
Is it OK to store data, that is needed by the plugin for the currently open 3dm file, inside the PlugIn instance during run-time? Is it guaranteed that if there are multiple Rhino instances open concurrently, there will be a separate PlugIn instance for each Rhino instance?
This is of course, assuming than when the file is saved or opened the data will be serialized to UserData of the file.
Thanks,
Taavi
Yes, each Rhino process has its own instance of your plug-in. There is no shared memory between processes.
