When importing images into Rhino document it would great if images could retain path information where the image came from (perahps accessed via “What” command). I think that it would be helpful in later identifying the image.
Images do retain that information at least as textures. The path should be visible through the texture panel. Select a texture and you should be able to see the path of the image.
Brilliant, thank you
