Store a Brep as JSON data and create a Brep from JSON data later
I need to store the Brep in JSON format, and later recreate these Breps from the JSON file. For certain reasons, I cannot use the Brep’s ToJson method (I’ve tried it, but the exported data is not human-readable). Does anyone know how to solve this?"
this is a json file
brep.json (59.2 KB)
this is my code
 if (obj is BrepObject)
                    BrepObjectData data = new BrepObjectData();
                    SetCommonData(obj, data);
                    BrepObject brepObj = (BrepObject)obj;
                    Brep brep = brepObj.BrepGeometry;
                    List<BrepFaceObjectData> BrepFaces = new List<BrepFaceObjectData>();
                    foreach (var bf in brep.Faces)
                        BrepFaceObjectData brepFaceObjectData = new BrepFaceObjectData(bf);
                        BrepFaces.Add(brepFaceObjectData);
                    data.BrepFaces = BrepFaces;
                    data.GeometryJsonData = brep.ToJSON(options);
                    data.ObjType = (int)ObjectType.Brep;
                    data.WireDensity = (int)obj.Attributes.WireDensity;
                    dataList.Add(data);
this is BrepObjectData
    public class BrepObjectData : RhinoObjectData
        public string GeometryJsonData { get; set; } = null;
        public int WireDensity { get; set; } = int.MaxValue;
        public List<BrepFaceObjectData> BrepFaces { get; set; } = new List<BrepFaceObjectData>();
        public List<CurveObjectData> CurveData { get; set; } = new List<CurveObjectData>();
this is BrepFaceObjectData
public class BrepFaceObjectData
        public List<CurveObjectData> BrepFaceEdges { get; set; } = new List<CurveObjectData>();
        public int BrepFaceIndex { get; set; }
        public bool IsPlanar { get; set; }
        [JsonConstructor]
        public BrepFaceObjectData()
        public BrepFaceObjectData(BrepFace bf)
            Brep brep = bf.DuplicateFace(false);
            BrepFaceIndex = bf.FaceIndex;
            IsPlanar = bf.IsPlanar();
            foreach(var e in brep.Edges)
                NurbsCurve nurbsCurve = e.EdgeCurve.ToNurbsCurve();
                NurbsCurveObjectData nurbsCurveObjectData = new NurbsCurveObjectData();
                foreach (var cp in nurbsCurve.Points)
                    nurbsCurveObjectData.ControlPoints.Add(new ControlPointObjectData(cp.X, cp.Y, cp.Z) { Weight = cp.Weight });
                nurbsCurveObjectData.IsPeriodic = nurbsCurve.IsPeriodic;
                nurbsCurveObjectData.CurveType = CurveType.NurbsCurve;
                nurbsCurveObjectData.StartPoint = new PointObjectData(e.PointAtStart);
                nurbsCurveObjectData.EndPoint = new PointObjectData(e.PointAtEnd);
                nurbsCurveObjectData.isClosed = nurbsCurve.IsClosed;
                nurbsCurveObjectData.IsEllipse = nurbsCurve.IsEllipse();
                BrepFaceEdges.Add(nurbsCurveObjectData);
What do you expect “human readable” Brep data to look like?
If you could explain the reasons why you can’t use the ToJson method, that would help as well.
this is part of my json data,which i think is human readable
    "$type": "Flatfish.ObjectData.BrepData.BrepObjectData, Flatfish",
    "WireDensity": 1,
    "BrepFaces": [
        "BrepFaceEdges": [
            "$type": "Flatfish.ObjectData.Curve.NurbsCurveObjectData, Flatfish",
            "ControlPoints": [
                "X": -211.0,
                "Y": -72.0,
                "Z": 0.0,
                "Point3d": {
                  "X": -211.0,
                  "Y": -72.0,
                  "Z": 0.0
                "Weight": 1.0
                "X": -138.0,
                "Y": -72.0,
                "Z": 0.0,
                "Point3d": {
                  "X": -138.0,
                  "Y": -72.0,
                  "Z": 0.0
                "Weight": 1.0
            "IsPeriodic": false,
            "IsEllipse": false,
            "GeometryJsonData": null,
            "StartPoint": {
              "X": -211.0,
              "Y": -72.0,
              "Z": 0.0,
              "Point3d": {
                "X": -211.0,
                "Y": -72.0,
                "Z": 0.0
            "EndPoint": {
              "X": -138.0,
              "Y": -72.0,
              "Z": 0.0,
              "Point3d": {
                "X": -138.0,
                "Y": -72.0,
                "Z": 0.0
            "Degree": 0,
            "Dimension": 0,
            "isClosed": false,
            "CurveType": 1,
            "LayerData": null,
            "ObjectColor": null,
            "ObjType": 2147483647,
            "objColorSource": 2147483647,
            "lineTypeSource": 2147483647
            "ControlPoints": [
                "X": -138.0,
                "Y": -72.0,
                "Z": 0.0,
                "Point3d": {
                  "X": -138.0,
                  "Y": -72.0,
                  "Z": 0.0
                "Weight": 1.0
                "X": -138.0,
                "Y": -72.0,
                "Z": 86.0,
                "Point3d": {
                  "X": -138.0,
                  "Y": -72.0,
                  "Z": 86.0
                "Weight": 1.0
            "IsEllipse": false,
            "StartPoint": {
              "X": -138.0,
              "Y": -72.0,
              "Z": 0.0,
              "Point3d": {
                "X": -138.0,
                "Y": -72.0,
                "Z": 0.0
and this is the result of ToJson method,i cant understand it at all
    "GeometryJsonData": "{\"version\":10000,\"archive3dm\":70,\"opennurbs\":-1902867635,\"data\":\"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\"}",
i need save data in json file,and i need use python to do some analysis work,that is why i need huaman readable json data
I don’t know how you expect the data to look like in Json. If you want to stick to Json, it sounds like you will need to extract the data you expect yourself.
If you don’t need Json, you could also take a look at mcneel/rhino3dm: Libraries based on OpenNURBS with a RhinoCommon style
