Hi everyone,
I am developing a C# component that includes an internal timer, which I use to automatically save files at regular intervals. However, I’m facing an issue: the timer keeps running regardless of the component’s status. For example, when the component is locked, I want the timer to stop, and when it’s unlocked, I want the timer to resume.
I’ve tried to implement this behavior but it’s beyond my current knowledge. Does anyone have experience or insights on how to control the timer based on the component’s state? Below is some of the logic I have so far:
// Main Autosave Component Logic
public class AutoSaveComponent : GH_Component{public int IntervalMs { get; private set; } = 900000;public int MaxFiles { get; private set; } = 5;
private Timer saveTimer;
public string AutosavePath { get; private set; } = @"C:\Temp\gh_autosave";
public string LastAutoSaveTime { get; private set; } = "---";
private string unsavedFolderName = null;
public AutoSaveComponent() : base("AutoSave", "AutoSave", "Automatically saves Grasshopper documents at a set interval.", "APP", "Template")
SetupTimer();
// --- Initialize the autosave timer ---
private void SetupTimer()
saveTimer = new Timer();
saveTimer.Interval = IntervalMs;
saveTimer.Tick += (s, e) => PerformAutoSave();
saveTimer.Start();
// --- Update autosave interval ---
public void UpdateInterval(int newIntervalMinutes)
IntervalMs = newIntervalMinutes * 60000;
// --- Update maximum number of autosave files ---
public void UpdateMaxFiles(int newMax)
if (newMax > 0) MaxFiles = newMax;
// --- Perform the autosave ---
private void PerformAutoSave()
var doc = OnPingDocument();
if (doc == null) return;
try
if (!Directory.Exists(AutosavePath)) Directory.CreateDirectory(AutosavePath);
string folderName = ResolveFolderName(doc);
string saveFolder = Path.Combine(AutosavePath, folderName);
if (!Directory.Exists(saveFolder)) Directory.CreateDirectory(saveFolder);
string timestamp = DateTime.Now.ToString("yyyyMMdd_HHmmss");
string fileName = $"{folderName}_{timestamp}.gh";
string fullPath = Path.Combine(saveFolder, fileName);
GH_DocumentIO io = new GH_DocumentIO(doc);
io.SaveQuiet(fullPath);
// --- Remove old files exceeding MaxFiles ---
var files = new DirectoryInfo(saveFolder).GetFiles("*.gh").OrderBy(f => f.CreationTime).ToList();
while (files.Count > MaxFiles)
files.First().Delete();
files.RemoveAt(0);
LastAutoSaveTime = DateTime.Now.ToLongTimeString();
ExpireSolution(true);
catch (Exception ex)
Rhino.RhinoApp.WriteLine("AutoSave error: " + ex.Message);
Thanks in advance
