hi guys, can you help me… im trying to make this file convert to stl.. but it almost 3 hours and nothing has change until now. the setting 0.5… can someonehelp me to fix this problem or convert my file to stl..?
ffWhat printer are you using?
If you print on a Bambu Lab, you can export *.stp
Meshing should not take that long. I suspect you have a bad object in the file that Rhino is having trouble meshing. Does anything select if you use SelBadObjects ? But the only way to really diagnose it is to post a link to the file for someone to download and check.
Wow, that’s about as much of a mess as I have ever seen…
779 block instances, 1 clipping plane, 34922 curves, 559 surfaces, 428 polysurfaces, 591 extrusions, 158 meshes, 4 SubDs, 200 hatches.
Mostly grouped, nothing joined, lots of surfaces with no thickness etc. Measures almost a million millimeters along the diagonal…
Sorry, but frankly I wouldn’t know where to start - maybe just first scale the thing down to a correct size for 3D printing, then count on hours of fixing. Maybe you could Shrinkwrap it, but…
It is recommended to quickly export STL using the following method:
- Run the
ExtractRenderMeshin the command line, then select all the objects you want to export. - Run the
SelLast, then continue by running_Exportand save as an .stl file
