I am attaching a STL that I exported from a project. Every setting I can find in the project is set to inches and no matter the settings in any STL viewer I have tried, it is still not the correct dimensions… roughly 14x20 inches…
I wish that were the case… The width of the rectangle in Rhino is 14.505" wide. Every unit possible (that I am aware of at least) in the project file settings are in inches.
When I export it to STL and open it in Fusion360 it measures 5.7106" wide.
But if I open it in an online STL viewer I can get it to the correct size… so the lesson today is… “Kid’s, don’t allow your parents to use Fusion360. It will not end well for them!”
Yes, tis true… but imported into a document whose units are in inches. I do not think I have ever set any documents units to centimeters… the lesson remains… Kid’s don’t let your parents use F360!
