Still can't mouse button swap for navigation?
Hi, I’m new to Rhino but have 25 years muscle memory in Solidworks and 15 years in Maya and Blender, which makes navigating Rhino very challenge due to its reversed nav mouse buttons.
The workaround is through my mouse software, it remaps the mouse buttons for Rhino only. That works great for navigation but it creates confusion as some Rhino commands use right or left mouse button as trigger.
This reminds me of Blender back in the days when it too was using its own reversed mouse button functions which made it difficult for Maya and other mainstream 3D modeling users to make the switch.
Blender popularity exploded when it introduced the UI option similar to mainstream software. I see this feature request dates back decades without being implemented. IIRC, Blender has option to keep its original mouse functions in addition to the mainstream UI option. Rhino could do the same?
Hi, @John167…
Here’s a small correction that works in your favor: the mouse-button remapping you’re after has been in Rhino since the Rhino 4 days. What’s never been built is the friendly part, i.e. a preset dropdown that says “Navigate like SolidWorks.” The settings are there; the UI dropdown isn’t.
Options > Mouse > Middle mouse button. Check Manipulate view, then:
Configuration Behavior
Manipulate view + Rotate MMB drag orbits, Shift+MMB pans, Ctrl+MMB zooms
…plus Swap Shift and Ctrl for pan and zoom Shift+MMB zooms, Ctrl+MMB pans → this is SolidWorks
Manipulate view + Pan MMB drag pans, Alt or Shift+MMB orbits → this is AutoCAD/Fusion
NOTES:
A. For 25 years of SolidWorks muscle memory, check all three.
B. Blender’s scheme is the first row on its own, no swap.
You don’t lose the middle-button popup menu or popup toolbar either. Click and hold instead of dragging, and it still comes up.
Then delete your mouse-software profile for Rhino. That’s the actual source of your command-trigger confusion: Rhino was being handed swapped buttons and had no idea. Once MMB is navigating natively, Rhino’s left and right buttons mean what Rhino thinks they mean, and the commands behave.
Also NOTE: right-mouse button drag will still rotate in a perspective viewport, and there’s no setting to turn that off. It’s additive rather than conflicting, so you end up with two ways to orbit, and you’ll gravitate to the one your hands already know. Give it a week before you decide it’s a problem.
On the larger request, you’re right that a preset list would lower the wall for people arriving from other software, and Blender is the correct precedent. That’s logged as RH-31346 Wish: UI Navigation Presets to mimic other software and still open. I’m adding this thread to it so your case is on the record.
