I am encountering an issue while importing STEP files into Rhino.
When I load a STEP file, all imported objects initially come under the Default layer. After the import, I programmatically move the objects to their respective mapped layers.
However, I am observing unexpected behavior related to block/instance definition geometry.
Issue Details
During STEP import, the importer sets Default as the active layer.
Because of this, definition geometry for instances is created on the Default layer.
After the import, only the instance objects are moved to their mapped layers.
The definition geometry remains on the Default layer.
As a result, Rhino displays elements appearing in both the mapped layer and the Default layer, which creates confusion in layer organization.
Hi @lander,
Thanks for the suggestion. However, exploding blocks changes object IDs and removes instance structure, which is important for our workflow.
Is there a way to update the layer of instance definition geometry directly (via API or import settings) without exploding the blocks?
To change attributes, e.g., layers, of objects in block definitions while retaining the objects’ GUIDs:
Via UI, sub-object select (Ctrl+Shift+click/window) the objects in the block, then modify their attributes in the Properties panel. Objects, excluding the instance objects themselves, in nested instances can also be selected this way.
