Step Export with Materials
Hello. I want to export my 3D model (with materials) as step and import it to another software. Instead of the materials I get the layer colors as materials. Is there a way to export the materials from with step?
Thank you
Hello - no, there is no provision for that - however object colors are kept, so a script that matches object color to material color before exporting is a possibility. You would not get the material, but the material’s base color applied to the object.
@vinzenz.weiss - this Python makes the objects have material color on export - I’m not sure if that is of any use but have a try.
ExportObjectsToMaterialColor.py (730 Bytes)
To use the Python script use RunPythonScript or a macro:
`_-RunPythonScript “Full path to py file inside double-quotes”
@pascal, is there plan to providing this?
