STEP export: Rhino 8 ModelObject block instances and nested assemblies
Hi ShapeDiver team,
We are building a STEP export for a shelving configurator and would like to preserve its assembly structure and repeated parts.
Our environment:
  • Rhino 8 SR35: 8.35.26251.13001, Windows, .NET 8
  • ShapeDiver plugin: 1.33.0
  • Download Export with STEP Export Options, schema AP214AutomotiveDesign
Our Grasshopper C# builder creates native Rhino 8 ModelObject blocks / ModelBlockInstance objects containing BReps, including nested block definitions. It does not bake objects or modify the Rhino document. All placements come from a JSON manifest.
The intended hierarchy is:
Configuration → shelf bays / supports → part instances → BRep bodies
When connecting the root Model Block Instance directly to Download Export D, with the standard STEP Export Options connected to O, “Export locally” fails with:
No objects match the types supported by the selected export format.
The configuration exports successfully when the builder outputs the placed BReps directly. However, this loses the intended block-based assembly structure and shared part definitions.
Our inspection of the installed 1.33 SDK suggests that the STEP/STP object-type filter excludes InstanceReference. We tried extending the export options, but script review rejected this and advised us to file a support request. We have removed that workaround and are requesting an officially supported solution.
McNeel describes Rhino blocks and instances being converted to STEP parts and assemblies here.
Is there an approved workflow for exporting Rhino 8 ModelObject block instances to STEP through Download Export?
If this is not currently supported, could you add support for nested assemblies, preserving part and instance names, transforms, colours and references to repeated part definitions where supported by the STEP schema?
Automatic expansion to BReps would resolve the immediate export error, but our main requirement is a STEP file containing selectable parts and a meaningful assembly tree.
Thanks!
The currently supported behaviour is that block definitions can be exported using the export components as long as one instance is included in the export. The resulting file should include the block definition and the instance, and the “block-based assembly structure” as you put it should be respected.
If you are trying to do what I described above and it fails, please point me to a minimal example where the exported file does not respect the assembly structure, this might be an issue.
On the other hand, if you are trying to export a file containing only block definitions, and no instances or other geometry contained in the file, then that is currently not supported and it will fail. Our team could investigate support for this case, as long as it makes sense.
After some further testing, I could reproduce the issue. The export works for the 3dm file format but not with the STEP file format currently. As you mentioned in your message, the fix is to allow instance references when exporting to the STEP format. Our team will implement this behaviour and it will become available in the next release.
