Steel Node
I’m trying to figure out how can I make steel node similar to this one
I started by creating a tube, a copy of which I rotated around the center of its axis, but I’m trying to figure out how I can multiply that copy and rotate it in arbitrary/ directions.
Rather than create a single line then pipe it and and rotate it into all the different directions, the easier way would be to make the lines in the directions you want and pipe these
pipelines.gh (8.8 KB)
Nice thank you! And in this way i can adjust the number of the pipes through the set of integer
try multipipe node, from rhino 7
multipipe.gh (14.7 KB)
p.s you can play around with other inputs as well, in order to achieve much better results. Feel free to ask questions.
