Choose rotation of resulting edge
meaning the outcome currently is 90 degrees away from the cplane while most instance i believe it would need to be orthogonal to the cplane @DanielPiker i saw that you have considered to implement this here is there any status? will it be targeted at all?
Set Variable Radius
also i believe this has been requested a few times, not sure anymore if there is any progress. sidenote i am not yet using any Wip due to old computer system, sorry if this made its way in by now.
also regarding radius, a suggestion to set the radius by making a curve or using a curve editing UI element for instance. maybe its a dull suggestions but i have seen this in quite a few applications.
@theoutside come and have a look.
