Hi guys,
I am getting a 401 status (Unauthorized Error ) when trying to use Hops and targeting a virtual Rhino.Compute instance instead of local.
I followed the guide and set the IP address of the vm on the Hops settings, and if I run compute.geometry.exe
manually from the VM, I can actually see Hops trying to reach the /io
endpoint.
Any clues why this is happening? Am I missing anything?
Details:
I am running compute.geometry
on a vm using the following versions:
"rhino": "7.10.21256.17001", "compute": "1.0.0.1159"
Locally I am trying to use SimpleDelaunayMesh.gh
from the compute repo.
stevebaer
(Steve Baer)
October 12, 2021, 1:58pm
2
What “Path” are you using? It looks like Hops might be getting confused
For the Compute Server URL, something like this: http://111.222.333.444:80
and for the definition path on hops is just an usual file path.
Hey @stevebaer , after trying a bit more I got this error which might be what you mentioned regarding the path.
Any ideas what might be happening here?
stevebaer
(Steve Baer)
October 15, 2021, 2:35pm
5
Do you get any sort of different error message from the compute console?
I get exactly the same message.
After debugging deeper, I found the exception being raised at ApiKey.cs
more specifically at the CheckApiKey(Nancy.NancyContext context)
method.
The code makes total sense to me. What is not clear now is how do I pass my compute api key through Hops @stevebaer ?
stevebaer
(Steve Baer)
October 25, 2021, 11:23am
8
Hops doesn’t currently pass any sort of api key around. Do things work if you remove the api key environment variable and restart compute?
Yes, things do work! Might be useful to write this detail on the Hops docs.
stevebaer
(Steve Baer)
October 25, 2021, 12:24pm
10
Is there a reason you had the api key set?
@stevebaer Not really. It’s a production deployed server. I just followed the guide .
