Status bar layer column order
Is there a setting that forces the column order of the layer status bar pop-up order to match that of the Layers panel or to use V7’s order? I prefer V7’s order with the Layer column on the right.
7.37.24107.15001, 2024-04-16
8.8.24163.12481, 2024-06-11
Thank you
Hi Steven - I do not know of anything that can set this - I see that it is different from V7, I don’t know if that is by design or not… I’ll ask.
It is indeed by design, to better match the default layer panel layout.
