Charles
December 15, 2016, 10:35am
1
when starting the latest release (6.0.16348.9381, 13.12.2016), this comes up:
Rhinoceros WIP CRhCommandManager::RegisterCommand ERROR
Command did not register.
UUID: 7E8A7FA0-E373-30cc-A0F1-7936FEC05E
English Name: TextEdit
Local Name: TextBearbeiten
When I try the command ‘TextBearbeiten’, then Rhino hangs:
Next thing is when I right click on the Arrow button, Rhino asks a question instead of cancelling all:
-C-H-A-R-L-E-S-
brian
(Brian Gillespie)
December 15, 2016, 5:10pm
2
Thanks, that seems to be a combination of a couple bugs RH-37236 and RH-37180
brian
(Brian Gillespie)
January 18, 2017, 2:34am
3
RH-37180 is fixed in the latest WIP
my WIP build is 6.0.16362.6421, 27.12.2016, and wenn I try TextBearbeiten [= _EditText], I get the same result as Charles except for the error message. On the other hand, the written text does not even appear in the viewport’s text edit box.
The newcomer I am, maybe I just don’t know how to handle the command accordingly?
Charles
January 18, 2017, 11:59am
6
Joachim_Kuntz:
Joachim,
the current command is
_RTextEdit
(RTextBearbeiten)
In the beta from 2017.01.17 this works.
Also by double-clicking a text.
Regarding the cancel error, yes, this one is still there.
-C-H-A-R-L-E-S-
Charles:
I’ve just updated to 6.0.17017.13261 and now it seems to work, both by running the command or double-clicking the text edit box:
Would you agree according to the above screencatch? And if you would, can I close the following Youtrack Issue assigned to me? https://mcneel.myjetbrains.com/youtrack/issue/RH-37236
Thanks for your help.
brian
(Brian Gillespie)
January 18, 2017, 8:03pm
8
@Joachim_Kuntz Thanks for your work on this. I recommend you move the issue to “Needs Testing” instead of “Closed”. Doing so will send it through our regular testing process and get announced next week. Thanks!
Done. Thanks for your advice, @brian
Pitti
(Andrea Montis)
December 9, 2017, 4:04pm
10
In the latest beta I have this issue:
UUID: 712068FE-4313-3c92-9B80-BAFF3C1032
-English Name: UpdatePlugins
-Local Name: AggiornaPlug-in
brian
(Brian Gillespie)
December 12, 2017, 1:50am
11
Pitti:
AggiornaPlug-in
This will be fixed in the next WIP.
