When I select an object with gumball turned on the gumball is displayed at the center of the object. How do I find this same point to start a line or place a point? I’m sure there is a command or something out there…
Thanks,
Don
Thanks,
Don
You can run BoundingBox and then VolumeCentroid on the bounding box to get a point at this location. It seems to be the same spot in some quick tests here. Any luck?
That seemed to work, thanks!
