Create a VA project Create two levels On the fisrt floor create an annotation Block it Copy the block with the annotation in it on the second floor Create a top view layout Show and cut only the second level on the detail view (with VA level manager) Try to print
In raster mode it seems to work as it should.
In vector mode the text of the annotation disapear and objects behind the level are showed.
Dispaly mode set to wireframe
Hidden mode activated, one detail view on the layout, occurs on upper level with elevation cut plane activated and other floors hidden.
Cotations are in the same block, of the same style, on the same plane. Some are hidden and other not in vector mode. But there are all shown in the viewport and in raster mode when printing. Can’t find why…
Hi @flavien.bessiere I could reproduce the problem. If you explode the block with the dimensions, they should print out correctly though. I’ll report it to the development team and get back to you when they fix it.
