Stange behavior started at wip and now also in 7
Hello.
I build a model in both Rhino 7 and 8. I started at Rhino 8 WIP, but I go back and front mostly because sometimes I get strange behavior in WIP, like after changing projection to parallel right clip orbit does not work, or a clipping plane does not fill all clipping objects,
Especially clipping plane cap, which used to work until yesterday in 7. Now I also have problems there. It seems like there is hidden geometry, but there is not, and the fill from cutting objects has disappeared. I have disabled all plugins but the behavior didn’t change.
Also, in WIP when I am in perspective view and the camera orientation is close to the top, the model disappears.
I will post three videos, one from WIP and two from 7.
I think I found one issue.
It seems related to clipping planes created in WIP.
Now in 7 clipping plane works as expected.
Opening without any modification in WIP the problem of clipping plane fill remains.
But now rotating the view close to the top does not dissapear the model.
Also, every time I exit the Rhino 7 I get an error message from datasmith exporter.
Rhino 7 SR32 2023-8-9 (Rhino 7, 7.32.23221.10241, Git hash:master @ 3d9c816c4cd57561d12d8f53246bce304f314ba2)
License type: Educational, build 2023-08-09
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.32.23221.10241
but again make 2d is a mesh
Hi -
Videos and pictures are limited in what information they can provide. Please post - or upload - a 3dm file that we can check.
I uploaded the file.
Thank you.
Hi -
Thanks, I’ve put this on the list for a closer look:
RH-77020 ClippingPlane: No cap is produced
Note, if you change the document tolerance to 0.0001 (from the current 0.000001), this appears to correctly create the clipping cap in Rhino 8 here.
Thanks for the info.
RH-77020 is fixed in Rhino 8 Service Release 16
