Standard UV Layout : Setting for padding between UV islands
is there a possibility to set a certain distance between single UV islands without having to adjust the distance in the UV Editor manually?
best wishes,
Andreas
Hi @Andreas_Behmel
Unfortunately there’s not setting for that. Are you working with polysurface or SubD geometry?
With polysurfaces.
Would be a welcome setting or alternatively function if one could re-distribute the UV islands with a certain padding.
best wishes,
Andreas
I’ve logged a request for both ways:
RH-71901 Padding setting for surface texture coordinate
RH-71902 New command to adjust padding between texture islands
