Standard Layers not being deleted in purge command
is there a way, that some specific “standard layers” could be defined, which wouldn’t be deleted in the purge command even if they are empty/have no objects on them?
Of course there would be some workarounds…
Thanks for your replies.
Andreas
Hi Andreas -
As you noted, purging will delete all empty layers. You could probably create a script that only deletes empty layers that are not on a list of layers to keep.
