A few days ago I posted about a tool for creating stairs in Rhino. Since then, I have been testing and bug-fixing the plugin. Today I am releasing it and open-sourcing it!
It handles all types of staircases, from angled, to curved, to winders, etc.
Any flat curve works. Straight lines, arcs, freeform curves and polylines with sharp corners. The curve can be the stair’s mid line, inner edge or outer edge.
Winders at corners. A sharp corner becomes a fan of winder treads around the inner corner. Treads never overlap or leave gaps, at any angle.
Comfortable steps. Tread depth follows the comfort rule (riser + tread ≈ 46 cm) by default. No tread’s average depth goes below 18 cm, so sharp corners get fewer, wider winders.
Autoconfigure. Give only the total height: it chooses the number of steps, sizes the treads so the last step ends exactly at the end of the curve, and adds a rest step after every 15 steps.
Structure. A continuous concrete-like slab with a sloped underside, or floating planks.
Rest steps (landings) at any step, as deep as the stair is wide or with a custom depth.
Railings on either or both sides: glass with a metal frame, a metal railing, or a cement wall with a metal handle.
Step numbers placed flat on each tread.
Pyramid width. Each step can be narrower than the one below, snapped to the center, the left side or the right side.
Follows the curve dynamically. Move or edit the curve while the settings window is open and the stair updates with it.
Everyone is welcomed to modify or suggest changes either here or on Github
Disclaimer: A lot of the coding has been done with Claude. Some people prefer to avoid anything related to AI, and that’s why I want to be transparent.
Hi, the plugin still lacks the ability to control the winder/landing step. For example, in a ‘L’ shaped staircase, when the landing step is given at corner, it should be proper rectangular or square shaped. but currently the step follows the curvilinear shape instead of making it straight. If that could be controlled as well, it would be a better upgrade.
The request is completed. However, I don’t have the time currently to do a thorough bug test myself, so for now I will only release this to GitHub, if anyone wants to test the new version early they can do it there. https://github.com/char-papadopoulos/stairsgen-plugin/releases
