Hello, I am having this issue for a while.
If a stair is rotated relative to the world CP the numbers are also rotated: is there a way to fix that?
Hi @XDGA,
I don’t find a way to fix that for the moment so I have already reported the issue to improve this feature. For now, you can hide these numbers in the stair style and draw them manually using the Rhino text command.
ok, thanks. Pity, in a multistory building or a highrise it could be rather tedious indeed. I found a workaround tho: I made the core in a separate file and drew it in world coordinates, then imported it as a block: numbers are not rotated
