VisualARQ stairs currently provide virtually no control over their 2D cut/break representation in plan.
This is particularly problematic because the current VisualARQ representation does not follow the standard architectural drawing convention used in Romania and in many other European countries. Therefore, this is not simply a matter of graphical preference; for our documentation, the current representation cannot be used as it is.
Depending on the level from which a stair is viewed, I need three different representations, as shown in the image below:
Type 1 – View from the first level
The stair is cut, and the portion above the cut plane is shown as overhead/dashed.
Type 2 – View from an intermediate level
The stair is cut, but the flight coming from the level below must also be represented.
Type 3 – View from the last level
The complete stair is shown without a cut/break, since there is no continuation to an upper level.
These are not simply graphical variations of the same symbol. The required representation depends on the relationship between the stair, the current level, and any other stairs that may continue above or below. VisualARQ can determine this context automatically, but the user should be able to choose which cut/break representation to use.
Also the stair cut/break representation should remain graphically consistent. Its geometry should not change depending on the stair or cut configuration, unless that change is intended to convey different information. Otherwise, the resulting drawings become ambiguous.
At the moment, achieving the required documentation forces unnecessary manual 2D workarounds for something that should be controlled directly by the Stair object.
