Stair landing
In the VA stair tool there is a way to eliminate the tread on Landing arrival?Stair
@Leon46 you can specify the stair tread and riser slab settings from the stair styles dialog (vaStairStyles command)
@Leon46 I’ve just figure out that you only want to delete those treads from the landings. In that case the only way is using an auxiliary solid and running the vaSubtractSolids command.
My goal was to have a tread-free landing added during the creation of the staircase. so your first answer is the right one for my problem.
Tank
Leonardo
