hello,
I have two panels that I want to stack on top of each other on the right side panel.
I currently have the two panels showing on the right side but in the same container.
I would like to do it by code, can this be done with rhinocommon?
I see, is this much harder to implement than the current system ?
I understand that this might be a detail for you.
Do you know a workaround that I could use? It can improve the quality of life for the people using the plugin.
Thanks you for your time @dale
