Stacked block building
Hello, I am currently trying to generate a block stacked building where by i can generate different x and y values for each rectangle and be able to rotate each rectangle individual. However since i generated the points for the rectangles using divide curve i don’t have control over each individual rectangle.
If anyone knows how to achieve this, your help will be greatly appreciated
Can you upload your file please? Welcome.
Here is my file so far stacked block building.gh (10.0 KB)
Something like this?
2021-04-05 09-28-38.2021-04-05 09_30_38
The center line of the lift shaft now acts as a rotational axis. If you place it somewhere different the rotational behaviour will change.
stacked block building 2.gh (20.1 KB)
thank you sooo much
You’re welcome.
