SRFSPLIT fails at small tollerance
In one of my files I am working with a tolerance of 0.00001 instead of 0.0001 for several reasons that are not relevant to this observation.
When I PROJECT a curve onto a surface SPLIT fails at the lower tollerance. Just to be sure I EXTEND the curve to ensure full coverage of the surface but the SPLIT operation fails and the input surface is returned by the operation. If I SPLIT with a surface at this tollerance, it succeeds.
Would be nice to see some files.
I am still working to isolate this as an example …
OK here it is: R6 W10
t
u
SplitSrf 003.gh (16.5 KB)
Apologies for not including a file with my initial question. I presumed the answer was nothing to do with the underlying geometry and a tollerance problem like this:
Some people here will say that fillets are bad types of surfaces to work with, because they are degree 2 with point weights. You will find that rebuilding that surface (to degree 5 with 10 CP - rebuilding the surface within 1e-8 tolerance) will stop the split from failing. It feels to be a bug though.
(using rebuild surface from Pufferfish)
Aaaah ha. I suspect as much. Thank you for confirming that I need to rebuid that surface. I came to the same conclusion, and have begun to work on rebuilding every trimmed surface from the underlying geometry
