after upgrading Rhino (Windows) from SR16 to SR17 i’ve found that i get strange errors which did not come up before. For example using keywords like below:
brep.DuplicateNakedEdgeCurves uses an unknown keyword “outer”
the helpdoc however specifies exactly the keywords used. If i remove them the code runs OK.
I also found that SR17 runs some code used extensively here noticably slower. Is there a list of changed methods from SR16 to SR17 which could help to pinpoint the cause ?
Hi @dale, thanks for the list. So it implies that the only change for windows is this:
SDK: 3dm export allows specifying a different unit system
I am not doing anything export related in my code, however i see it runs noticably slower compared to Rhino 7 SR16 after the update. Code which used to take 0.1s now takes 1.2s to finish. I am running this code hundrets of times, whenever the user edits a point…
Hi @dale, a whole lot of code, actually 1200 lines just for the point editing which is run after each mouse up. I have one system still running SR16 which i try to use to compare with one which was updated to SR17.
Thanks, the info for SR18 RC1 doesn’t list anything i use. I’ll try to profile and time my code to find out which function and method is causing it.
I confirm the same script-breaking change. The keywords for Brep.DuplicateNakedEdgeCurves have changed from outer and inner in RC 7.16 to nakedOuter and nakedInner, respectively, in RC 7.17.
