Its possible to ‘reset’ the squish command in Rhino 8, because i run a script that probably change the configuration of squish that it don´t work properly.
Can someone try to do the squish, to see if the result is the same.
No changes that I know of in Rhino 8 would have affected that.
@PedroNeves What is your issue with the current result? I imagine it’s the sawtooth profile in the middle of the squished surface? Do you know of a time when Squish worked better on the same surface?
Do you want a way to reset the settings of the Squish command to their defaults? Restarting Rhino will do that, as they do not persist across sessions.
