Issue:
Squidtexture is appearing on objects in Rhino, but not Shapediver.
The texture does seem to work if it’s baked into a bitmap, but not if it’s updated on the fly.
The example is based on this script, which seems to work okay. I can’t tell why the example script works, but mine does not… shapediver-squid-demo.gh (348.3 KB)
The reason for the texture not showing up is the “Swis721 BT” font which is not installed on ShapeDiver servers. After changing it to a supported font, the script works as expected.
Also, I noticed in that the static internalised meshes could be optimised and reduced in size (number of vertices) which would improve performance of your model. See following Forum post and tutorial for more tips:
