I was using Squid ShapeDiver edition to generate a bitmap that has a circular shape.
And I was using Fill Radial but somehow the bitmap is not aligned to the center of the input circle.
It slightly move towards to the X direction. See the image below. The Green Circle is the input to Squid component.
And from the Quick Preview, I can see the pattern is not visually centered.
Also, I thought maybe because of the Graph Mapper, so I changed it to linear distribution. Still the same with a slight shift of center.
I can avoid this issue by keeping the bitmap in the position, while creating another circle to align to the image.
But I was wondering if there is a reason that the bitmap is not centered?
Thank you for the definition. I could reproduce the problem and also created a minimal example using the regular Squid plugin, which also produces the issue:
@MateuszZwierzycki I can confirm that the radial fill seems to be a little offset on one side for some reason. Could you have a look? Unless we are doing something wrong here, let me know so we can coordinate a fix in both versions of Squid.
