Springs showing up strange in Beam View
I have a few springs between elements, but when examining forces/moments in Beam View the dimension of the spring is way off. It’s showing up as if it was an much larger element, when in reality the Spring is just between the circled nodes. Is there a visual setting I can change?
Hi, can you share your file so that we can help you to troubleshoot this issue.
The file is pretty dense and relies on both geometry from a large rh6 file and some robotic control components to run. Is there another way to diagnose this?
Hi, well it is difficult to check the file just based off an image. Is there any way that you can reduce the complexity
