Spot Lights
#1
Two questions.
  1. Is there a bug with spot lights? I added two spot light to shine against a wall and the light seems to go right through the wall.
  2. If I we’re download the Brazil demo, will all the materials and lighting work in Neon without a watermark or size limitation after the 15 day trial?
Same two spot lights. The light blasts through all objects at 50% power. My rendering program is set to Rhino Render but I also have Air, Flamingo NTX and Vray installed. Not sure if that matters any.
(Willem Derks) #2
Hi Billy,
First you might want to check what the shadow intensity the spotlight is set to:
Having this set to anything other than 100, will cause some light to bleed through objects, much like your renderings are showing.
HTH
-Willem
#3
Hi Willem,
Confirmed - The culprit is the shadow intensity settings. Anything less than 100 causes the light to bleed.
(Andrew le Bihan) #4
The answer to “2” is Yes.
#5
Thank you for the support. I’ll download Brazil demo and see if I can push Neon more.
