Hi everyone! To summarize, I can’t get Sporph to actually map the geometry I’ve provided from the base surface it’s on to the target surface I’ve inputted. The original input is a (non-capped) rectangular extrusion, and I want the mesh generated from each face of the extrusion to be mapped back onto the corresponding face of the original extrusion; it works for one face but for the remaining it just leaves them on the base surface instead of transferring them.
The script I’m actually working with is a little more complicated than what I’ve attached here, but just as a test to make sure there was nothing wrong with the components I had in the middle I internalized the Brep/Mesh values and kept only the beginning components (& the Sporph component), which proved that the issue was still persisting. Even if I explode the original extrusion and provide each surface separately, Sporph still doesn’t work correctly.
Sporph Fail.gh (1.1 MB)
