Michał
(Michał)
April 12, 2026, 4:09pm
1
Hi, so I wish for my sporph to set voronoi on exacly the surface that is visiable on the right, but i cant get it to work.
ponczek.gh (32.4 KB)
Your base surface is a rectangle. Your target is not saved in the file.
For the sporph to work, the base surface basically needs to be an unrolled version of the target. That means in your case the base needs to have the hole.
Please internalise the input data.
Baris
April 13, 2026, 9:41am
3
as far as I know, you need to use “CreateUVCrv” command in Rhino or a C# script, to get something that respects the boundaries:
260413_Sporph.gh (15.4 KB)
based on a script from the one and only HS_Kim:
Hi all,
i have faced some problems theses days paneling a doubly trimmed surface:
[geo]
I would like to have a clean edge,the image below is
[edge]
Thats also the reason why i tried to do it with a mesh from the output of the meshBrep component.
I know there will be distorted faces with less than 4 vertices, thats ok for me, i just dont get it done:
[MB]
I am not sure what could be a workaround.
Maybe someone knows?
Thanks!
LBSplit.gh (17.5 KB)
Best,
Baris
