Hi
I’m using ‘Split with Breps’ for dividing a closed curve with a set of 150 surfaces. It should return 150 open curves, but I got only 149 (and 150 points).
Using another closed curve, the same Split with Breps works fine (150 curves).
CrvSplit_with_Srfs.gh (601.3 KB)
What’s the problem here? Is this depending on the resolution of the model, or what? The closed curves have both some 5000 knots, and no apparent issues.
Also, are there other ways in GH (Rhino ver. 5.4.1 Mac) for achieving this, using perhaps other items? There’s the ‘Surface | Curve’ (which doesn’t work btw.,) but there’s no ‘Curve | Surface’ or ‘Split with Srfs’…
Please note that the set of surfaces is a restrain: using fixed distance, lenght or similar rules for splitting the curve is not an option here…
