I have a spiral shaped cut around a cylinder, where I want to remove the strip that is in the spiral shape. I am trying to do this programmatically with python, but I’m not so sure where to begin with the methods for splitting/trimming objects from the brep class. I think this application is a little more tricky too, since I am splitting a cylinder the seam breaks up the cut so the result is more than just piece A and piece B.
The file below shows the objects I start with, and the desired goal that I would like to automate into a routine. In summary, it’s using a closed curve to split a brep surface which is periodic, and the closed curve goes across the surface seam multiple times.
If the face is first split in two, my scripts, xTrimSrfWithCrvs / xSplitSrfWithCrvs | Food4Rhino , can trim/split those faces to your intended result. Depending on how far you want to automate your workflow, I can help you set up your script to use these scripts.
Dear Steve, that would be really helpful. Getting to this point, the work is done in grasshopper. Will I still be able to call your scripts through the ghPython component ? Maybe I need to dig into how I do that.
I think I must’ve looked at every class nearly except BrepFace … some of the classes, I didn’t understand so well. there was one, for example below, where it talked about getting numbers / indices to identify trimming curves, which you then pass back through later.
But I just noticed that though _Trim doesn’t work well on your example, _Split does. I then tested the even higher-level method, Brep.Split Method (IEnumerable(Curve), Double) , and this also works on your example even without splitting the brep first. So, this is my revised recommendation to try first.
Brep.AddTrimCurve is for the low-level construction/modification of a brep.
Hmm… doing this so far in a ghPython gives me the original cylinder. I could upload the file maybe, but I also don’t want to take up too much of your time.
I was trying to get my head around, in the API, how the trimming itself ‘happens’. For example, just choosing some curves to cut presumably isn’t enough. Do I then need to do things pertaining to loop type, and so forth?
Brep.Split acts similar to _Split; it even returns multiple breps instead of adding faces. Here is a script using it that works on your example:
Python code
from __future__ import absolute_import, print_function, unicode_literals
import Rhino
import Rhino.DocObjects as rd
import Rhino.Input as ri
import scriptcontext as sc
def main():
res, objrefB = ri.RhinoGet.GetOneObject(
"Select brep",
acceptNothing=False,
filter=rd.ObjectType.Brep)
sc.doc.Objects.UnselectAll()
sc.doc.Views.Redraw()
if res != Rhino.Commands.Result.Success:
return
res, objrefsC = ri.RhinoGet.GetMultipleObjects(
"Select curves",
filter=rd.ObjectType.Curve)
return
rgB_In = objrefB.Brep()
crvs = [o.Curve() for o in objrefsC]
rgBs_Out = rgB_In.Split(
cutters=Rhino.Collections.CurveList(crvs),
intersectionTolerance=sc.doc.ModelAbsoluteTolerance)
if len(rgBs_Out) < 2:
print("Brep was not split.")
return
print("Brep was split into {} breps.".format(len(rgBs_Out)))
[sc.doc.Objects.AddBrep(rgB) for rgB in rgBs_Out]
if __name__ == '__main__': main()
