As per some other discussions about Push-Pull modeling I was curious, so I prototyped a small script to draw a polyline on a planar polysurface face and then use it to split the face (inside the script). Then I stumbled on an interesting phenomenon I can’t explain.
In the file above, on the left is a (pink) cube with 3 split faces - they were split by using the script to draw the polylines on the faces and then split them - 3 separate runs of the script, one for each face.
In the part on the right (turquoise), I used the same polylines to manually split each face using the SplitFace command in Rhino (3 times as well).
They LOOK identical. The What command also gives basically the same info for each, a closed polysurface composed of 9 surfaces.
Now, subobject select, say the two ‘Front’ facing middle surfaces (the parts inside the split) and use ExtrudeSrf with DeleteInput=Yes and extrude them a bit into the cube. On the manual one, the behavior is as expected. On the script created one, the unused splits on the other two faces disappear! It appears that a MergeAllCoPlanarFaces is being called behind the scenes - but only on the script created object.
If, before extruding, I do a ShrinkTrimmedSrfToEdge on the script-created cube, it reports that 3 of the 9 surfaces were shrunk (the inner ones, of course). After that, when extruding one face, the unused splits no longer disappear. However, on the manually created split face cube, Shrink on the whole object also reports 3 surfaces were shrunk… So I still don’t see how they are different.
Can anyone tell me what is different in the geometric definitions of the two cubes that might be causing this?
Funny, no? there’s gotta be something a bit esoteric about the difference. I do have a hunch what might have caused this, but it would be cool to be able to figure out what’s different between the two by doing some sort of ‘autopsy’ on the two objects.
If you explode the left cube and rejoin before extruding, the inner faces no longer disappear. If you extract and rejoin just one, it no longer disappears but its compatriot still does.
And if you extrude with the gumball the inner faces don’t disappear.
The scripted split one seems to contain 6 surfaces and nine faces. The manual split one seems to have nine of each. I’d look at whether there is some mismatch in your code between the handling of these two types of object. It looks like your script is splitting the faces but not the surfaces.
It’s not exactly a mismatch, but yes, that looks like it is the problem - good catch. I split the face, which appears to return a valid, brep object with the splits, but it is not the same as actually splitting the brep and then joining the split results.
It is possible to make 2 faces reference the same surface.
We don’t do that because as you see it causes confusion later, but the brep definition allows it at a low level.
I looks like that happens with your script.
If I delete all but the front-facing plane of the pink cube and list the remaining brep, I see that the brep has 2 faces and 1 surface and both face(0) and face(1) reference surface(0)
Speculating here, I think the polysurface is duplicated in the process of extruding in to it and the original is deleted, but the duplicate may find two outer trim loops on the same surface and remove one of them or some such validation.
The first thing that would be good to figure out is what initially makes the two faces that share a surface. Splitting a face should duplicate the surface.
Here is a super simple example file and some code. Run the code, select the front face of the box, then the single closed curve that is on it. The result is a split face box that has 7 faces but only 6 surfaces.
import scriptcontext as sc
import Rhino
def GetOneBrepFace(prompt):
#if successful, returns base object and face index
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt(prompt)
go.EnablePreSelect
go.GeometryFilter=Rhino.DocObjects.ObjectType.Surface
go.Get()
if go.CommandResult()!=Rhino.Commands.Result.Success: return None, None
objref = go.Object(0)
if not objref: return None, None
index=objref.GeometryComponentIndex.Index
return objref.Object(),index
brep_obj,face_index=GetOneBrepFace("Select the front face of the box")
if brep_obj is not None:
crv_id=rs.GetObject("Select the curve on the front face",4)
if crv_id:
brep=brep_obj.Geometry
crv=rs.coercecurve(crv_id)
tol=sc.doc.ModelAbsoluteTolerance
#split the face
split_brep=brep.Faces[face_index].Split([crv],tol)
if split_brep:
sc.doc.Objects.Replace(brep_obj.Id,split_brep)
sc.doc.Views.Redraw()
print "Face count = {}".format(split_brep.Faces.Count)
print "Surface count = {}".format(split_brep.Surfaces.Count)
