Split VIewport
Rhino 8
Why does split viewport resets current single viewport back to 4 viewports with a split viewport? It should just split the single viewport into two. How do you get a vertical or horizontal split viewport?
Hi John -
I’m confused. That’s what your image shows, doesn’t it?
SplitViewportVertical or SplitViewportHorizontal?
I meant a full screen with just two splitted viewports. The only way is by dragging the borders, but the other two viewports are still there (highlighted in red box).
When you’re in single viewport mode, executing split viewport command should just splits the single viewport into two. It should not change the current single viewport back to 4 viewports mode and then split one of them into two.
Hi John -
Thanks for that clarification.
I’ve filed this as RH-96671 Viewports: Split Maximized Should become Two
You can start in a 4view and use the CloseViewport command to either close two next to each other or two above each other. Then drag the border.
When you have the viewports in the state that you want, you can save and close the file. Then, when you need the layout in a file that you are working in, you can use the ReadViewportsFromFile command to restore that viewport layout. You can assign that command and the file name and path to a button or alias to quickly restore the viewports.
