Could we get the split viewport command added to the task list. There are times I just need a extra view in some of my models.
The floating viewport command would also really be useful with this command as well on my second screen.
Will certainly be implemented, the question is when. (For me is the command that I look better)
Any update?
Rhino WIP _NewFloatingViewport
It has been marked “future”.
So, no definite release point at this time.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36727
You can use the _NewFloatingViewport command and then the “Moom” program https://itunes.apple.com/us/app/moom/id419330170?mt=12. You can also customize the window size with a key combination.
https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/6/9/695a5ce16f5cac5e7158de7e1f3804ba2f8eb5f2.mov
