Hello, I am trying to replicate a geometry I downloaded! I want to split/trim the upper surface/plane above the loft into smaller segments as seen in the green one! If you observe carefully the triangles are perfectly aligned along with the loft! You can bake the Brep(Replicate this) at the end of the script to get an idea of what I want to explain! Thanks in advance!
A is the surface made by me and B is what I want to achieve! So how can I go from A to B.
As seen in B, the surface is split in such a way that it matches the split surfaces from the loft! I want those perfect triangles on the edge of the loft!
